Firstly many thanks to David for your kind help and advice at last weekends Silverstone Classic.
Hi I'm new here but not new to Porsche Cars as had many over the years, mostly new.
So having now ventured back in time to a 964 C4 Targa 1991 I knew I would be chasing some problems.
Now having done a lot of replacement and improvements over the past year the only problem I'm now left with is the CCU fan cutting out as soon as the temprture is turned up from zero, I managed to remove and send the CC unit to a company who said they could test it, but then said they couldn't ??
I've read the article on here saying replace the fan ballast resistor on the rear blower unit, however I wouldn't know if that will cure the fault, so thought I'd ask here first as David kindly suggested, anyone had the same fault and found what is needed to cure it please ?
Many thanks, Rob, Hove.
