Hi,
After my crash at Castle Combe and general unhappiness at the way the ABS was working on my C2, I sent off the pump and ECU to Autotek and they have come back and said...
Cost £377 for the ECU and £460 for the pump.
That seems like a lot to me but them hopefully my ABS would be working correctly after this.
Has anyone any experience of Autotek and if what they are quoting is resonable ?
Second hand units would be cheaper but how would I know that they are working as they should.
Also, has anyone replaced their ABS pump ? Is is just a simple case of attaching all the pipes and bleeding the brakes and clutch or do you have to take steps to avoid getting air trapped in the system ?
"We have tested both ABS ecu and the pump and found them to be faulty. It seems the ABS pump motor assembly has overloaded the control module and refurbishment is required."
