Does anyone has 4x4 964?! Today I had strange problem. On my gauge (second from left) red light with picture of differential (4x4) was turned on!once I turn off the car and left it for 10 min, then start it and try to drive everything is O.K. for several miles, then the lamp is on again.After seeking and trying to fix problem I noticed that my ABS isn`t working! I tought that maybe some ABS sensor is damaged so after a while he is sending wrong info to comp. There is one pump (which is pumping oil through brakes and ABS system) situated in front, below hood! I disconnected both cables and returned them back, after that everything is working now!I dont know why that lamp was turned on?that pump has nothing with differential (at least I think)!
If anyone had similar problem please help.
Thank you
Thank you
