958 Cayenne Diesel - brake and pad renewal
- Thread starter Mike Pink
RCS
When we had a 997.2 OPC quote was a lot, again £1k mark. Spoke with my trusted Indy and using Porsche parts (car was under warranty) they could do it a bit cheaper - they said big issue was price of Porsche parts. I may again explore what their price would be compared to the OPC, as I do trust them, may even look at whats needed to do it myself. I did quickly look at parts and they were not cheap! My servicing will be OPC (although Indy is cheaper) to keep book stamped and avoid any issues.
Thanks Kevin, I really hope I don't need them, but the discs do wear and as I want the warranty (peace of mind, etc), I'll have to accept a disc change if outside Porsche's prescribed wear limits. Can't even dream of aftermarket pads - however better some can be - as P are renown for their pedantry on the warranty compliance. (There are plenty of daft things rejected - like the Road Angels dealers used to fit, then found Porsche disapproved; or radiator-protecting mesh, only fitted to the GT3. Wouldn't be surprised if, for example, a tail-gate related claim got rejected by someone having fitted after-market sun visors; or a wipe-motor claim got rejected because one of the wheel centre-caps wasn't a Porsche one! Compared those, fitting non-OEM brakes/pads would be a heinous crime!)tiskev said:I have never had any complaint about after market pads .Discs I have never changed
but are yours that bad ? Even if they are a bit worn how much braking efficiency is lost ?
Do PCGB members still get some discounts of fixed prices and parts at OPC?
My pad warning light came on the other day so I checked my options. Eurocarparts offered Pagid or Brembo. I have a high regard for Brembo (Italian) brakes from my motorcycling days so happy to go with them. (Pagid or ATE may be oe fitment). The parts cost about £620 including 4 wear sensors but I got lucky with a 1 day 30% off deal so paid £433 all-in incl VAT.
My local garage are happy to fit them and couldn't match the £620 let alone £433!
tiskev
Furthermore if you put Brembro stuff on the car they are hardy likely to look
at brakes if the engine blows up ?
Check your local VW outlet I find quite a few VW bits are the same and half the price
Look at wiper blades for a start.I would guess the KN and Toureg have same brakes ?
