951 geometry settings
- Thread starter moore
chrisg
As per a recent post, much depends on what you're using the car for track vs Road usage.
As a compromise for good road handling, I would suggest:
1.5 -itive at the front with 0 toe-in/toe-out
1 -itive at the back - not that easy to adjust and requires a certain amount specialist knowledge as to which bolts/ eccentrics to twiddle.
FYI, the front end camber adjustment is very straightforward and as per all Macferson strut vehicles
If you need any more info or help - PM or ring on 07540 193874
robwright
Anything in brackets is for USA.
Just about all the settings were out, expected the front being wrong has I have just had refurbished koni's and 968 camber blocks fitted.
Seems to be well balanced on initial drive out.
All ready for the run down to the Classic Le Mans.
