944 Wheel Alignment
- Thread starter blade7
Jonny944CS
Some recommend welding an extension to the spigot on the standard tool to achieve more leverage.
Jonny944CS
Can anyone recommend a good wheel alignment service in the Oxfordshire area?
I used Chris Franklin several years back, who did a great job, but is certainly not local.
I recently tried a local garage with a good quality Hunter laser system. The result was poor, with the operator struggling to get the rear camber/toe anywhere close...
If the trailing arms haven't been off the car for a long time, then I recommend having the mechanic remove and clean the fittings and thrust faces on the trailing arms and spring plates. Sorry I can help on recommendations on who to use though!
Its a bit of a faff but it can be done and done well! Being as I'm making ongoing changes it makes sense for me to do it myself.
bellaboots
