944 turbo
- Thread starter pauljmcnulty
Suffolk944
Moderator
ukmastiff
sawood12
Fat Albert
Well that was the main Factory power and speed enhancement wasn;t it?[ORIGINAL: edh Lots of red cars on this thread - keep it up []
pauljmcnulty
Of course, there are cheap cars out there worth buying but they are very rare. The standard recommendation is to buy the car, pay for all the known faults to be fixed and then allow £1K on a Lux and £1.5K or more on an S2 or Turbo for the things you didn't spot. Think about it, add up sills at £1K per side, wings at £500 per side, respray to include the stone-chipped PU and badge panel, sort out the bit of rust around the tailgate pins, hell; respray the whole car whilst we're at it. New sunroof and tailgate seal, few bits of interior trim, gearshift is sloppy, need a wishbone and a 4-wheel alignment. Those fuel lines are looking dodgy, there's caliper corrosion and the brake lines are shot. The clutch might be the old rubber type, belts are due next year and water pump is original...... Ok, that's being very negative, of course. But, I'd guess that every car out there needs one or more of these jobs doing. The point is, you could be looking at many £000s if you buy the wrong car, but it'll be less if you buy one that's got evidence of at least some of the known weak spots dealt with. I wish people would understand that these are better cars than anything of the period, and most of the cars that have come along since. That doesn't mean that they are bargain-basement cars to own, just better value than most of the rubbish out there. Spending the money to keep them at their best is essential, and buying a good one is a sensible starting point even if it's overpriced.Ive read a lot re buying the 'best car you can afford' etc but just a thought , I have no excperience of Porsche ownership but have had a lot of cars since turning 17 like most folk , some very good ( never forget that classic sunbeam Ti) and some very very bad ( most of those by Rover) . It seems clear that dropping 2,000 on fixing up your cheeply bought 951 would be very easy indeed but you could of course spend £5000 on quite a good one and still pop bang wiz spend 2,000 on problems.
