This might be of some interest to those interested in tuning. I have been data logging my first fiew journeys in my 944 turbo which is fitted with a re-mappable DME that I have been working on. Many of you might have followed it over the last couple of years. It's been a lot of work but finally sitting in my 951 and hearing that turbo spooling has really made it seem worthwhile! It has 55lb injectors, dual port wastegate, hybrid K26/6 turbo, head ported and internals balanced and of course my MAP based DME.
You can view them with megalogviewer http://www.tunerstudio.com/index.php/megalogviewer which is a free download http://www.tunerstudio.com/downloads/MegaLogViewer_setup_v3.1.1.exe. I started tuning it from scratch and at each stage I have done a bit of tweaking then logging then more tweaking. I am using a sensor clamped to the tail pipe so some times at low rpm you get high AFR's due to reversion. But actually this new innovate motorsport AFR clamp is pretty good. The car is now road legal here in the UK. Tomorrow I will be installing an EGT sensor into the crossover pipe which will plug into the DME and tonight I will write some code to do closed loop AFR control with the wideband input.
First trip (using a raw guesstimap): https://sites.google.com/site/tomsite1234/files/944%20Turbo%20%28Un-Tuned%29%2030.10.2012.csv?attredirects=0&d=1
Second trip (passenget tuning the fuel table) https://sites.google.com/site/tomsite1234/files/944%20Turbo%207.11.2012%20%28First%20tune%29.csv?attredirects=0&d=1
Third trip (maps are just modified from experience road tuning): https://sites.google.com/site/tomsite1234/files/944%20Turbo%207.11.2012%20%28Second%20tune%29.csv?attredirects=0&d=1
The car is running well, smooth and responsive. Not really venturing much into boost at the moment although I could not resist on the odd occasion
. She needs running in for a few miles a good checkover and an oil change and then a trip to the car treadmill I think
. I will keep updating this with new logs and hopefully eventually some dyno charts
Tom
Tom
