Dan944t
hi guys,
need a strange bit of knowledge if anyone knows or can figure out past what I was going to try.
when I pulled my engine few years back the tourque tube was a pig to pull out of he bell housing, and I noticed later on the following year that I’m pulling from the rear to pull te front splines out of the clutch and bell housing, i seem to have pulled the torque tube casing itself back a bit obviously sliding over the bearings inside thus making the front of the splines protrude further forward and at the rear its obviously gone forward into the tube.
By how much im not sure at a guess possibly 80mm plus?
question is does anyone know the measurement say from the front tube flang to the very front of the spline, so I can press it back in?
i could muck about with trial and error but obviously once the engine is in the bay it’s a no go getting in the and knocking it back, and I don’t fancy keep putting it in and out as not to disturb the clutch allighnment let alone the frustration it will cause.
ive thought of measuring how deep the spline hole is through the bell housing and working it out that way but wouldnt want it to come up short or long once I’m trying to join the gearbox spline at the back.
then I thought I could measure from the back as if the tourque tube flang was bolted flat on the gearbox and leve a 10 mm gap between the two splines?? It’s just that I can’t remember the gap it had now as it was a few years ago since I’ve pulled the engine and box from the car.
https://imgur.com/a/WBSbz3J
atb
Daniel ??
atb
Daniel ??
