944 turbo S2
- Thread starter yipadee
One of those 3.0 8v turbocharged things that Baz Hartech was developing? Perhaps? [&:]ORIGINAL: 944 man
Whats a '944 Turbo S2' ?
ETA: If the brakes on the car are in decent nick (as in, pads and disks still have reasonable wear left on them) and it's not sharp enough then you need to be looking at the circuit. When was the fluid last changed, and when was it recently bled? If neither of these have been done in the last 2 years then I'd start there.
pauljmcnulty
944 Turbo, or 951.
S2 means Series 2, as opposed to series 1 which is the early-dash model.
I'll just shut up now. [
944 man
ORIGINAL: pauljmcnulty
944 Turbo, or 951.
I'll just shut up now. [][
Please dont make this worse... [
With regards to braking - if the OP has a 250bhp car, then surely the brakes are more than man enough for the job? Are you sure that theyre working properly?
Which ever brakes you have I very much doubt you'd be complaining if they were working properly so I'd get them re-furbished first. Then think about upgrading.
sawood12
ORIGINAL: yipadee
road use want sharper braking
New discs wont get you sharper braking. These things don't have over-servo'd on/off brakes like newer cars so you do have to stamp on the brakes harder and you will get longer brake travel. This gives you impression the brakes are not sharper - but you just need to stamp on them more. There is more than enough braking performance if your set up is in good working order. If you want better cold bite ditch any aftermarket fast road/performance pads if you have them and install standard pads or equivalents. Make sure you have fresh brake fluid and they are well bled and all the brake lines are in good nick.
