944 turbo model history quick question
- Thread starter djcla
Diver944
In 1989 all Turbos had 250bhp and the 220bhp was dropped (there may be one or two 220 cars that sold during 1989 due to leftover dealer stocks)
The easy way to tell the difference is the engine code stamped on the block by the exhaust manifold for cyl #4.
250 cars are coded M44/52
220 cars are coded M44/51
pauljmcnulty
Diver944
ORIGINAL: djcla
Anyone know how they got the extra power
In simple terms they fitted a bigger turbocharger that could hold the boost of 0.85 bar to 5800rpm
You can easily chip a 220 car to 1 bar of boost and reliably make 280'ish bhp with less lag than the 250 car. The same process to a 250 car will yield circa 300bhp
Today I had a ride in a 250 Turbo Cabriolet chipped (and the rest) to 1.4 bar yielding 416bhp [8D]. New trousers were required afterwards [
morris944s2john
hartge bob
To go to 250 brakes on a 220 you need calipers, discs, pads AND new hub uprights, the caliper mounting on the 250 is different to the 220.ORIGINAL: djcla
brakes wise , are the 220 brakes different from the 250 models? If you needed to upgrade the brakes would you need new pads, disks and callipers or just disks and pads? Plus any suggestions on which brakes to get?
Peter Empson
ORIGINAL: djcla
tell me is it fairly simple i.e. cheap to convert a 220 turbo to the 250 version? ANyone know how hey got the extra power
Depends on you plans for the car, but I might suggest (and I'm sure I've read it from those that have owned/driven both) that the 220 can actually be a bit nicer on the road as it has less lag. It will also be slightly lighter (although I'm not sure by how much) thanks to things like those smaller brakes, and reducing unsprung weight is definately a good thing in my experience.
Diver944
ORIGINAL: Peter Empson
It's much easier to fit the much lighter callipers from a Boxster/996 to a 220 car than to a 250 (as I have learnt this week [&o])
hartge bob
That's interesting Paul,ORIGINAL: Diver944
Do you know how this would compare to a big black setup in terms of pad area, weight saving etc.
Is it just a bolt on for 220 hubs or is bracketry involved?
Diver944
You cannot do it on the 250 car because even though it too is mounted radially, the bolt holes do not line up for the 996 callipers.
The callipers are apparently much, much lighter and also benefit from not having the calliper plate issue. They are also freely available at breakers etc. The pad and disk size are comparative with the Big Blacks, or you can go even bigger by fitting the 6 pot GT3 callipers and disks, but then you have to use 18" wheels
ORIGINAL: Diver944
Today I had a ride in a 250 Turbo Cabriolet chipped (and the rest) to 1.4 bar yielding 416bhp [8D]. New trousers were required afterwards []
I just read about that one......nice ought to be a candidate for "the rollers of truth", so we can see how it compares! oh.....but there are no rollers any more just a hole in the floor![
Diver944
ORIGINAL: jackregan
.....but there are no rollers any more just a hole in the floor![]
EEK what's this? Have they removed the rolling road from Weltmeister? It was there back in October for our last Dyno Day
Peter Empson
