944 Turbo Exhaust
- Thread starter Guest
Suffolk944
Moderator
sawood12
sawood12
Suffolk944
Moderator
pauljmcnulty
ORIGINAL: mattpone
cheers guys
essential's exhaust looks great but at nearly £650 thats an expensive bit o steel!
have requested some info from hayward and scott though see how that compares
Call Darren at RPM Porsche - he brought a newly developed exhaust to the autojumble at Cornbury House.
944turboS
http://cgi.ebay.co.uk/Sports-Exhaust-NEW-PRODUCT-Porsche-944-S2-Turbo_W0QQitemZ140051193927QQihZ004QQcategoryZ10408QQrdZ1QQcmdZViewItem
Dyno chart is under 4" system. But I would prob get big flow as its one jump from 3" 2 4"
Rather then 3/3.5/4 and the waste gate is tied in to the larger 4"
Section.
They sell fabspeed as there 3" Polished options which are prob slightly better then there 3"
System but most power comes from 3" decat test pipe. So I can see why the hp difference would be measurable
Fabspeed also use to offer 4" back box as well
It would seem 4" system starting earlier should be better yet.
Not sure what the shipping rate is on the LR but is £350
On fabspeed b4 duty.
Have u noticed much impovement for yours Scott
944Scott
Actually yes.
It definitely has more torque, boost seems to come on sooner and the car feels smoother and uses a little less fuel. Before the rear section was made I was running with 3in outlet pipe, 3in decat pipe and standard rear section. When running in the manner the car would make a sort of warp warpp warppp sound under load and this has now gone too. Now the exhaust has coked up a little it has quietened down quite considerably so im really impressed considering it only has one smallish silencer.
944Scott
Doing it again I would go the same route however I was a little unhappy with the overall finish of the decat from H&S and I cant help thinking it would have been cheaper having it made on the day at the same time as the rear section by Vortex. They were very helpful and Natalie actually reduced the cost of the system slightly on the day plus if I had done it this way the silencer could have been fitted elsewhere. They did comment that they normally fit the raceflo system before the silencer but because of my reluctance to cut into my decat pipe it is fitted at the rear of the car with the silencer just before it, I love the look of it but they did say I might be losing a couple of HP.
944Scott
Its not that noisy and the Raceflo actually seems to suck so much of the gases out that it gets quieter at speed, no real droning [
