Hi Folks,
Been troubleshooting a strange boost issue in my turbo where intermittently the car stops hitting maximum boost, so far I've found a loose inlet manifold banjo bolt so tightened that up and then I turned my attention to the diverter valve that I got from Promax a few years ago.
I pushed the piston up with my finger to test the vacuum (by placing another finger over the vacuum port to seal it) and then letting go to to check the operation. It worked the first time but didn't seem to open very far so I pushed it again and then it jammed and wouldn't release.
I've opened it up via the 6 small allen head bolts and removed the piston and spring, there appears to be some moly grease inside the valve to lubricate the piston but it is very sticky so I'm checking if anyone knows what it should be lubricated with? Looks like the o-ring / seal they use on the piston reacts with the lubricant that was put in at the factory and swells causing the piston to seize. Quite how long this has been going on I don't know but I'm pretty sure this is what has been causing my weird issues, hopefully it hasn't damaged anything.
Found lots of forum posts on other car forums where people were experiencing issues with the Bailey (and to some extent Forge) aftermarket diverter valves and the piston seizing in the body due to either lack of lubrication or swollen o-rings (which appears to be the case with mine).
Looking through old forum posts I can see that Bosch stopped supplying Porsche with the OE diverter valves a few years ago and now they are made by a company called "Kayser" but are only available directly from Porsche! at the princely sum of £150... I've been lucky and managed to find someone selling a new one for £50.
From what I can tell looks like Bailey may have gone out of business? their website is still up but says they were moving to a new website in 2013... also no other shops appear to sell them.
So there are few replacement options unless you want to gamble with an expensive Forge, Turbosmart or APR diverter valve or chance it with a Febi Bilstein for the Audi 1.8T...
Looking forward to fitting the replacement and seeing if my boost issues are cured, if not my next plan is to temporarily remove the Lindsey Racing boost enhancer that was on the car when I got it in 2007, I'm concerned that the boost enhancer maybe allowing the turbo to overboost in certain conditions...
