Hi Folks,
I don't suppose anyone has the following parts? Looks like I threw mine out with some scrap metal!
I need the larger crescent washers (B) that go under the bolts on the outer cv joint, and the toothed spring (thrust?) washer that sits on the inside of the driveshaft.
Can't find the toothed washer anywhere, the 33 tooth one for the standard 944 shaft is a VW / Audi part...
Thanks!
Thanks!
