944 Teledial Offset Help
- Thread starter jp987c
Short answer - they’ll physically fit but will stick out about 3cm further, some have found that it fills the arches nicely others have found they stick out too far and can foul the arches as these cars do vary a fair bit.
Eldavo said:When you say "doesn’t have ABS fitted” I’m assuming you mean that the ABS system has been removed as the later cars had different hubs, etc. to accommodate the ABS system so they remain "late offset” unless someone has retrofitted early suspension to it.
thanks for the reply, yes my car is a later 944 (October 87 build) and has the later larger hubs but ABS wasn’t fitted as I believe it was an option? I may be wrong there though.
The wheels I would like to fit are 15x7 teledials with the earlier smaller offset. my car is on standard suspension and ride height.
thanks for your help
