944 Tappet Refurb?
- Thread starter barks944
bmnelsc
Even if they don't come apart - barks944 and Frenchy are on the right track - dissolving the varnish and removing the sludge will make a big difference - and even if the pistons are a little worn and you are not getting full valve opening because they can't hold full pressure - its better than having the valves not closing completely or on-time due to gummed up action.
david924s
Found this on Pelican Porsche and it seems 928 units can be dismantled so maybe those of us with 928, 944S2 or 968s can split the tappets, the same article also makes comment about ultrasonic cleaning so this could be a easy option.
http://forums.pelicanparts.com/porsche-928-technical-forum/551007-hydraulic-lifters-cams.html
I think before doing anything you would need to get the existing oil out of the tappet. When you take them out of the cam housing the pistons are rigid due to the oil in the piston. I have managed to get the oil out of a couple of spare tappets such that I can move the piston by hand. I guess then it would be worth soaking it in solvent. However I'm not entirely sure how you would get the oil back in after if you can't get the piston out. Aren't you supposed to re-prime the tappets before you re-fit them?
