pantswagen
turbo -post 86 front spindles, hubs -back plates, calipers -struts, wheel nuts
rear pre 85 hub with the alloy caliper mount and back plates -drums pins clips -spacers
964 -1990-91 rear 2 piston rear calipers
289mm by 20mm 71 - rear discs
20 wheel nuts
951 - cup 2's, the 8.5 ones, plus a pair of 951 fronts
would love some m030 front spindles, /hubs 928gts front discs and calipers -dream on eh?
ideally some aftermarket s2 944 struts, that utilise thinner springs, adjustable springplates and damp.
I am in london, will collect
-ideally i want 1990 964 caliper seat, 289-rear - 305/298mm by 28 calipers, although methinks i will need the 944 turbo fronts, as the discs may not work?
-ie i think they are 305mm by 32mm
unless i can just run the 964 front discs on the 944/951 hub - i know the offsaet of the disc is 5mm greater
0774 858 2044
-thanks -steve
-oh ps, the reason is, i think i need to use a 19/19mm master cylinder, rather than a 19/23mm one?
20 wheel nuts
0774 858 2044
-thanks -steve
