gilbo
Hi. I have just had a fair bit of work done to the car including a rear driveshaft inner joint which was in a real bad condition. The car had been in storage for a long time and I expected some things to need doing.
The problems with the rear started about 100 miles after I got the car and the racket was that bad It could be heard by pedestrians when I was driving past them - very embarrassing! Now it's fixed and there is no noise.
One 'problem' I still have, although I don't know if it's a problem or normal?? is that when the car is stationary and on a slight hill or incline, it will not budge when the handbrake is off. A steeper incline will cause the car to roll, but I tried to push the car into my very tight garage the other night with the gear lever in neutral and the handbrake off and with no incline at all it was a real fight to move it. Is this normal or could it point towards a problem with the brakes or the handbrake?.... or the other joint?
There are no smells or noises at all and the car drives and brakes normally. Just on my mind, thats all.
