944 sills
- Thread starter Derventio
pauljmcnulty
Derventio
I think they're probably the ones for sale on eBay from classiccarpartsandpanels.co.uk. I've looked into these and they seem to be the best bet for me as the top section of the sill is fine. There's also a repair section for the front of the rear wheel arch (after the sill repair panel) which I'm going to need. The downside is when I contacted them I was told that the current lead-time is 8 weeks and (of course) I wanted them yesterday! I'll see if I can post some piccies as I'm doing the job...
John
Derventio
John
Derventio
John
pauljmcnulty
https://www.classiccarpartsandpanels.co.uk/product-category/porsche-body-panels/porsche-944/
al
i visited the bodyshop last week to see how they are getting on with the old girl, and even though the basic shape of the wing bottom repair panels were there, they needed quite a bit of work to make them fit properly according to the bodyshop guys. the offside front wing bottom actually took a full day to fettle and weld into place to fit properly.
just be aware that although the sills and wing bottom repair panels are of a basic fit, they will still need work to fit.
hth,
Al.
I can say that the quality is excellent, made of fairly thick steel. Price was good too.
I also got the 8 week rhetoric - however I got them to do it in about 1 week by asking nicely (They said 4 weeks but lo and behold they arrived)
Would recommend, and as soon as they are done get a underseal spray gun and a tube on the end and fill the inside of the sills with a lot of underseal and you should be able to preserve them for a long time!
George
I haven't been on this forum for a while because my car has been off the road for the last eight years, after I was made redundant and establishing my own business.
I'm going to need to do the sills on the right hand side, if there is an 8 week wait and the panels are hand made I might just make the sills myself. I can't really afford £360 for the Porsche item!
The idea is to revive the S2 this year, and I will be starting a restoration thread in a few months as soon as I can get the S2 back down the workshop. I've collected most of the other parts needed for the restoration.
cheers
John
I bought a driverside replacement sill from the above mentioned vendor, as i thought thats all i required.
When both sills and rear quarters were taken back to metal it was decided to completely replace both sides including rear quarter section, as there were several pin holes and metal was quite thin.
The supplied sill reqired quite a bit of reworking to make it fit correctly.
So much so my body guy advised against buying the other repair section and made them himself.
I have the car back and have the luxury of another 944 to compare the restoration work with. Which is to a high standard.
I also have the removed metal work which i will post pictures of once my car is finnished.
For me personaly i would not buy the copies again.
markstephens
