944 safe jacking points
- Thread starter peanut
appletonn
http://www.cannell.co.uk/944_workshop_Manual/Vol3-chassis.pdf![. [FONT=verdana,geneva"] [FONT=verdana,geneva"]](/forum/styles/default/pcgb/space.gif)
Big PDF file from Rick's site, but under the body part of the manual you will find some B&W pics of exactly where to locate the lifting arms of lifts and also where to put trolley jacks.![. [FONT=verdana,geneva"] [FONT=verdana,geneva"]](/forum/styles/default/pcgb/space.gif)
Have fun!![. [FONT=verdana,geneva"] [FONT=verdana,geneva"]](/forum/styles/default/pcgb/space.gif)
peanut
You'd have to be crazy to risk it.
I thought that there were alternative positions but if not I'll make sure they jack on the front crossmember and rear wishbones
that diagram doesn't even remotely resemble the 944 anyway ?
pauljmcnulty
It's upside down, Peanut! [
It's a US spec car, see rear bumper. The front jacking points are only used on a 4-point lift and meant to support 1/4 of the car's weight. That's why the floorpan will distort if you use this alone. For that reason it's not marked on the diagram!
edh
I think the best jacking points are in the middle of the sills & underneath the gearbox. - I don't think I could get a jack under the front crossmember of my car - it's hard enough finding a jack that's low enough to get under the sills.
