944 S2 wheel offset question
- Thread starter markrreid
bmnelsc
So - you should be good to go unless you pick extra wide tires. I have read numerous comments on 944s being "different" from side to side, etc but that seems vehicle specific...
924Srr27l
Check by taking off one of the nuts and measure how much stud is left, then subtract 5mm
Also check if the centre hub has more than 5mm of spigot, otherwise the wheel will not fit dead central
R
924Srr27l
bmnelsc said:You shouldn't have any trouble but you should use a 5mm spacer on the rears to get back to factory offsets. The 944 Turbo optional wheels (16") were 7.5 and 9 inches and wanted standard late offsets of 52mm.
Adding width with a 5mm spacer on these ET47 Rear Wheels will decrease the ET number to ET42, NOT increase it to
the ET52 figure.
The best way to remember how offset numbers work is to think of the Early car's 944's inc the 16" Teledials on the Turbo used low offset numbers like ET23, then Porsche changed the and reverted back to Et55 front and ET52 rear with the D90 16" wheels on the S2
Imagine drawing a line through the centre of a wheel then measure from this to the hub mounting face, the bigger the
measurement the more the hub is towards the front face (Like the ET67 928 rims) and the lower the more dished the wheels are like early ET23 Fuchs etc..
R
924Srr27l
markrreid said:now I’m really confused! Has anyone fitted any with this offset? If so - any issues?
This can often be the problem with incorrect info you read or are advised etc...
Firstly what Wheels are on the car now ? Orig S2 D90's 7j & 8J ?
If so from the info on these 17" rims the differences are as follows:
Front
7" Et55 to 7.5" Et52 the inside of the rim will be 5mm closer to the strut leg and the outside of the rim
will stick out 8mm more.
Rear
8" Et52 to 9" Et47 the inside of the rim will be 9mm closer to the inner wheelarch and the outside of the rim
will stick out 16mm more.
I don't think either will be an issue, and will all fit without needing any modifications or spacers.
Tyre sizes 225/45/17 & 255/40/17
R
944 man
924Srr27l
944 man said:People suggesting that "late cars have an offset of 52mm" dont really understand offset. You could say nominal offset of 52mm (on a 7" wheel), but this will change as the wheel gets wider. Think of it this way: youre trying to keep a line that runs through the centre of the wheel rim in the same place, irrespective of the wheel's width or the way that the hub's mating surface has been machined. If you move from a 7" wheel to a 9" wheel but retain a 52mm offset then t will be in a completely different place. This is more important on the front wheels than the rears (as shown by Porsche's casual approch to centrelines vs aesthetics), but the principal remains the same.
Nominal means by name only only yes? a word I heard being used in a Michelin training session when referring to the first number of a tyre EG: 225 which they said is by name only and not the actual section width..
Only the later 944 7J fronts were ET55 and the rears ET52 in 16", except the Forged type 7x16 ET65 (951 Part number) and their rears from the (928) 9J Et60 not ET67. And Et52 in 15" all round
Porsche certainly did seem to make a hash of the various combinations the moment the early 944 was produced, quite why they decided to leave the front wishbones the same length as the 924 but in essence stick wrong and incorrect sized (ET23) offset wheels on it to fill the wider arches??, which of course totally messed up the KPI, the scrub radius and geometry!
This is why the steering on a Manual rack on early 944's is harder to turn (than a 924S) and the revised later 944's with longer wishbones
Strange why they decided to do it properly and revert back to Et 50's offsets although the strut angle was now jacked outwards more than previous which I think still affected the original negative scrub radius as originally designed for project EA425.
The first 944 Turbo Teledials did have ET23 offset front and rear, as did the 2nd gen Et52.3 all round.
The good thing is there are many combinations available not just in the 944/968 ranges but also the Boxster, Cayman and 911 wheels can all be used...
R
924Srr27l
944Turbo said:The nominal width comment reminds me that the N type (Porsche spec) Bridgestone S02 225/17 was wider than the 'non N type' 225/17 by about 12mm maybe they didn't have a mould for 232/17!
Tony
Yes I'd never heard of this either until Michelin informed me! , but as you say it does explain why when people change from one brand to another why some brands have a narrower or wider tyre width, and this Industry terminolgy means the manufactures can vary the actual size as it's by name only and doesn't have to be exactly as described & Measured!
Here's a shot out the Michelin book on the 225/45/17:
SW = Section width
OD = Overall diameter
RC = Rolling Circumference
SLR = Static laden Radius
Their 225/45/17 section width is 234mm but just above this their 225/50/17 is 242mm wide !
R
Have just purchased a Black 944 S2 Cabriolet (well, collecting saturday) but it has Boxster wheels on it which I'm not a fan of. Really want to put some Fuchs on it but trying to track some genuine rims down in the right size seems impossible (now I've got my head around the different sizes and offsets for the different models!).
Basically it seems in order to get a decent set of repros (can't seem to find genuine Fuchs in the right size) then Braid is the best option and they can make to order.
Before I put an order in I just want to double check with the 944 hive mind that I'm ordering the right size:
1990, 944 S2 Cabriolet
Have asked for:
2no. 17" x 7" Offset +52
2no. 17" x 8" Offset +52
CB 71.6
PCD 5x130
How does that sound?
Thanks in advance
Standard wheels sizes (and offsets) are in the owners manual,
Standard S2 D90s, front 7 x 16 ET 55, rear 8 x 16 ET 52,3.
M030 D90s (Turbo / S2), front 7 1/2 x 16 ET 65, rear 9 x 16 ET 52,3.
I've just been looking for some larger 17" wheels for my Turbo and have gone for a set of Cup 2 replicas that are 7 1/2 x 17 ET 52 (front), and 9 x 16 ET 47 (rear).
I'd recommend putting the standard D90s size into this tool and then playing with your planned wheel sizes to see how much they stick out (or in).
Alloy Wheel & Tyre Fitment Calculator. Offset, Tyre Stretch and Speedo Error | Will They Fit
This is an excellent tool. Thanks!Hi Ben,
Alloy Wheel & tyre fitment calculator - it calculates inset, poke, speedo error, tyre stretch and loads more.www.willtheyfit.com
