944 s2 replacement wings
- Thread starter mart1922
pauljmcnulty
Why do you need both wings? If it is because of two accidents then you're unlucky!
It seems that most second-hand wings will be suffering from some corrosion at the bottom edge. With this in mind, by the time you've bought, painted and fitted two used wings you will still have to deal with the rust!
Would it be easier to repair rather than replace?
I have tried porschapart but no luck.I will try PH sportscars tommorrow.
Thanks.
