944 s2 maf
- Thread starter NEIL2
TTM
Well-known member
It's not cheap but it nicely improves throttle response, is a quick & easy fit, and if ever the sensor goes wrong (mine hasn't yet) it should be easily available from any Bosch supplier at a decent price.
TTM
Well-known member
I would say it is a worthwhile upgrade for the gains in throttle response alone.
Coupled with a chip designed by the guy running SciVision, a German reg '91 S2 made 235.9 PS on a rolling road in Germany.
edh
This is the Scivision MAF I think - not cheap...
http://www.deutschnine.com/mm5/merchant.mvc?Screen=PROD&Store_Code=porsche-transaxle&Product_Code=D9-944S944S2-MAF&Category_Code=porsche-transaxle-944-turbo-s2-tuning-handling
Identifying the component parts and doing it yourself would be a LOT cheaper (although a lot more hassle. And you'd need to work out the converter chip.)
Over £700 is a large price to pay for a little more crispness in throttle response. That's about 1/5th of the value of a decent S2 these days, and far too much for my budget.
Big Dave
http://www.porscheclubgbforum.com/tm.asp?m=423726
It gave my car a LOT better throttle response + made the car that much more enjoyable to drive... Not sure of any increase in BHP but it definately felt better....
As far as im aware, this IS the only one that is currently for sale in the UK...
Peter Empson
944 man
Simon
sawood12
The tricky thing about MAF conversion, if you are retaining the motronic ECU, is not the integration of the MAF sensor - that is relatively striaght forward, but it is the interface with the motronic allowing the MAF to be used properly i.e. fuelling based on air mass calculations and not airflow. The Scivision kit incorporates a small computer which carries out all the mass airflow calcs in real time and provides the correct fueling signals to the motronic system. These things take alot of time to develop and test before a safe saleable solution can be offered. That is where the expense comes from and not simply the cost of the component parts.
