944 S2 Brakes
- Thread starter AcC8braman
blade7
Well-known member
colin944 said:£799 each for a front caliper new from Porsche . So rebuild is worth it even at half that price.
People are talking about spending more than half the price, hardly a bargain is it?
Monkeythree
Anyway after some engineering the larger 44mm scraper seals are in, I ground a "lead in" chamfer on the edge of the seals, Thomas at Pro- Calipers has told me he fits them just using a flat bar across them and making sure they are square, he is more talented than me if that's the case.
Should be on this week, yippee do dah !
Anyone after a completed set of fronts that will fit MO30 but have 42 & 38 mm pistons as opposed to 44mm / 40 mm drop me a line and they are yours for £400 mint and ready to fit.
blade7
Well-known member
Frenchy said:Anyone after a completed set of fronts that will fit MO30 but have 42 & 38 mm pistons as opposed to 44mm / 40 mm drop me a line and they are yours for £400 mint and ready to fit.
In light of what's been written here they sound like a bargain. Anyone have a link to a step by step overhaul with pics for late turbo calipers?
AcC8braman
blade7 said:Frenchy said:Anyone after a completed set of fronts that will fit MO30 but have 42 & 38 mm pistons as opposed to 44mm / 40 mm drop me a line and they are yours for £400 mint and ready to fit.
Just had a call to say my lift plate bolts won’t budge and need drilling which means helicoil!!!
vitesse
robwright said:Why can’t they weld a bolt on the top and get them out that way? The heat breaks the bond also. That’s how everyone else does it.
Last ones I did ,welded M8 nuts onto the dome head sets using a MIG welder to plug weld the centres.
Small socket ,extension & ratchet & they were out-as said the heat also breaks the Loctite type stuff.
Waylander
that is the best way of getting them out, MIG a nut on the top,vitesse said:robwright said:Why can’t they weld a bolt on the top and get them out that way? The heat breaks the bond also. That’s how everyone else does it.
Calipers with 36/40 pistons are now £836 each
or if you wish to go nuts the M030 36/44 Piston Calipers are £1105.06 each
so a full refurb for 2 for £400 is a dam bargain
blade7
Well-known member
Waylander said:Calipers with 36/40 pistons are now £836 each
Depends what you mean by a full refurb? My take is that's just seals and paint, and maybe bleed nipples.
Waylander
once they have had a good clean up and re-lube new fluid seals and dust seals they are as good as new
PSH
I don't do track days and I don't brake hard, in fact, I drive as taught by my father (a professional driver) who taught me to always use the gears. It's not so much to slow the car but to always be in the correct gear to react quickly to any given situation. Today's youngsters are taught to 'block change' coast up to a set of red lights in whatever gear they are in and then change down...that to me is 100% bad driving...no way have you got full control of the car. My wife was taught to drive like this, (she didn't start driving till late) I recall her following me to Wales when we had 5 children and decided for the first time to take both cars, she'd only been driving a couple of weeks. Anyway we took the 'horseshoe' pass route...perhaps not the best thing for a new driver but she's a spirited lady...I noticed her struggling getting up the steep incline and had to stop and go back....problem...she had always been taught to 'block change'...nothing about being in the right gear for the right situation...to you and I this may seem stupid, I assure she's isn't.... when you are new to driving, very new, perhaps what I would call 'common sense' doesn't kick in when you're so new to something. In her defence we don't have hills around here so she was never taught to down change for an incline, add 'block change' teachings and it was to be expected, she thought I was joking when I said she may need to stay in 2nd to go up the pass in traffic.
The moral of the story...perhaps this is why today's drivers are crap and dangerous to others.....anyway..I've deviated off the subject matter....must be my old age.......
Pete
AcC8braman
AcC8braman
Bolt condition
AcC8braman
Waylander
the plate bolts look like a Miged Nut on those plus the heat would not be too bad to get out, the main Allen Bolts are now finished,
the cross over pipes are dam expensive from Porsche, £93.00 a caliper.
If you went with Porsche for New everything to rebuild.
the Parts alone would be £363.00 without paint, OH and I forgot the bleed nipples at £20 each x 4
AcC8braman
Waylander said:Porsche and Brembo do not recommend splitting the calipers for any reason,
Bugger, this is getting blimin expenses!!!
Porsche recommend not splitting the calipers though not sure why ?
