944 s1 exhaust manifold question
- Thread starter Lance
chrisg
I'm not familiar with the exhaust manifold on the S1. It can't be that different to the S2 as the exhaust port spacing etc is all the same.
Is it a cast iron manifold or a tubular one as per the turbo/ S2 ?
If its a tubular one you'd be as well taking it to a skilled welder and asking them to take weld it in situ, then remove it and weld it up fully off the car.
Trust me, 2-3hrs of welding n labour will cost a lot less than a replacement manifold or a new one.
The other question you need to consider, is why & where has it cracked ? ie is the engine moving around too much as the engine mount(s) are shot or is the exhaust not supported properly or loose ?
yours
Chris
944 man
The S is S2 is short for Super. The 944 Super was a 2.5l 16v car and the 3.0l car was a Super 2. BOTH of these cars are series two 944s and there is definitely no such thing as an S1. A series one 944 has a 924 derived dash and every car from the 1986 model year onwards, built from September 1985>, is a series two.
HTH
