944 S Suspension upgrade advice?
- Thread starter Hallsy
edh
ORIGINAL: 944 man
GAZ tubes are extremely susceptible to corrosion too. One salty winter makes them look like theyre 10+ years old.
And my KW's still look shiny & new - 5 years on...
JagdHamster
I've been considering these (allows torsion-bar delete) instead of M030 rebuild:
Paragon Koni Coilover Kit £ 950+delivery
Ground Control Coilover kit with Camber mounts £1240+delivery
Russ
JagdHamster
Russ
JagdHamster
Russ
JagdHamster
Bilstein B6s
These would be okay on an 89 Turbo, right?
Russ
ChasR
ORIGINAL: JagdHamster
These seem mighty tempting for the money:
Bilstein B6s
Russ
As long as you do not have M030, then yes it should fit fine AFAIK
ORIGINAL: 944 man
A friend of mine with a daily driven MGB with a Gaz Damper conversion did actually key his dampers and lacquer them It seems 2 years on that they are standing up OK to the test of time. Can you not get them in the black finish for not much more?
JagdHamster
How much modification would be needed on an M030 car to fit those Bilsteins, because that's what I have? I'm trying to compare M030 rebuild (approx. £150 per corner at best guess) with these.
Russ
ChasR
JagdHamster
Give Design911 a call to find out?
Chas,
I think you're right. Shame, as I do like Billies and they are a very good deal.
Russ
charlieb
(I am not sure on the rules on posting this but the below is what would be involved so posting for information purposes only and I am sure if anyone is interested it may be of use)
The B6 package with full fitting and fettling comes in at about 1500 quid.
To me that sounds like jolly good value if you are not too sure on doing the work yourself. The list of work is extensive as below.
ï‚§ Test drive and report
ï‚§ Inspect all suspension systems and components including dampers, springs, bushes and balljoints
ï‚§ Remove existing dampers
ï‚§ Dismantle springs and top mounts from existing dampers
ï‚§ Rebuild Bilstein B6 dampers with original springs and top mounts
ï‚§ Re fit
ï‚§ Pre load car with weight
ï‚§ Tyre data check and adjust
ï‚§ Ride height check and adjust
ï‚§ Including Torsion bar adjust
ï‚§ Corner weight check and adjust
ï‚§ Geometry check and adjust (optimise for A/B road use)
ï‚§ Re check corner weights
ï‚§ Customer test drive check and handover
ï‚§ Before and after tyre, ride height and corner weight report
ï‚§ Before and after geometry check and report
Certainly don't think it would disappoint someone looking for a refresh. Now have to convince myself it is the right thing to do!
Cheers,
Charlie
charlieb
What am I missing then? I think they rebuild them from scratch with the B6 inserts?
Suspension not my strong point at all as you can probably tell. [
OLD_ian
ian
ORIGINAL: charlieb
For those interested in the B6 set up I got my quote back from CG
ï‚§ Re fit
Cheers,
Charlie
