MonkeyRacing
I've just fitted new strut inserts to the front & AVO adjustable rear dampers to my '83 944. I've also pushed the rear wheels out by 15mm each with proper bolt on spacers. Now i'd like to lower the car by 15-20mm. I know a number of manufacturers offer 30mm lowered front springs but thats a little too far in my opinion bearing in mind i believe the range of adjustment on the rear torsion bar is in the order of 15-18mm without re-indexing. I actually bought a pair of AVO 30mm lowered springs & changed my mind about fitting them after seeing a few pics of other cars. Perfect for the track but just a wee bit too dumped & Essex for me! I'm going for subtle here not would be track day weapon.
Do you know of anyone that manufactures a lowered spring of 15-20mm?
Would those from an S2 or Turbo work/fit & achieve the desired effect?
Has anyone tried spring compressors? Seems an agricultural solution to me!
Am i likely to have any fouling issues on the rear arches as my car has the factory optional 16" Fuchs with 205 tyres? It's going to be tight but someone out there may have some first hand experience.
Any other issues i need to think about, balljoints etc?
Si
Si
