Rapsey0909
Hi all, sure someone can answer this very easy.
I think I need a new coil and looking around the bosch coil is discontinued so I can see that design 911 sells an aftermarket one but its over £100 plus delivery.
Most coils I look at are 12v and the bosch coil is 14v (if that matters) but if I look at MSD or Pertronix the voltage is not stated.
Pertronix looks to be the best value for money but does not state a volt amount just that it will work in the vast majority of applications. So will this work just fine or will I have issues (do I need anything to go with it) or can someone suggest a coil that works goes great, goes straight in and that will not cost an arm and a leg.
Cheers all
Porsche 944 1986 2.5 NA
Cheers all
