Hello! Recently my 944 started stinking of a rich mixture, common problem I know so I ordered up my oxygen sensor thinking that was the most likely culprit and thought no more of it until I got the car up on the lift and found my '83 model has no oxygen sensor.
Supposedly being a final year engineering student I was suitably embarrassed that I hadn't even checked this, but now I'm going about it the right way and trying to test all the sensors that affect the computer's mixture control before attempting a repair or ordering the replacement part.
So my question is this - which sensors on my car affect the computer's mixture control? Obviously the MAF air flow meter and the DME temperature sensor will affect it. But what about the speed and reference sensors? Are there any other sensors that might be failing thus forcing the computer into a rich base mode?
Would like to get this sorted soon as the car consumes fuel at an alarming rate - used a quarter of a tank to do about 40 miles...
Symptoms:-
Extremely poor fuel economy
Exhaust stinks of rich mixture hot OR cold
Car idles poorly at all times, but worse when cold. It's doing ~500rpm idle when cold and ~700rpm hot.
As soon as you touch the throttle, car bursts up and runs fine, if a little lumpy around 1000rpm.
Exhaust quite often pops/backfires on the over-run.
Would appreciate any thoughts on this! Thank you
George,
Dundee, Scotland.
Symptoms:-
George,
Dundee, Scotland.
