944 front indicator internals
- Thread starter PSH
PSH
they are well beyond pickling....the parts in the top of the picture are fine.. the lower ones are beyond help and these are the parts that give power to the bulbs so need to be replaced. I'm in the process of fabricating some new ones out of brass, should give better electrical contact and won't rust although can oxidise if they get wet again. I'll see how this works out if no one has found a supplier of the original parts, I'm a bit apprehensive in getting units from a scrap yard as there's no guarantee that they won't be the same.
Pete
PSH
I've had a busy day fabricating new metal internals for my indicators, I used what was left of the originals as templates and cut out some new bulb holders from brass sheet. Once shaped and folded they did the job although I'll have to leave the test until a get some new bulbs, the old ones had welded themselves in..lol
First picture shows the old component alongside it's fabricated replacement with one unit test fitted behind
And a picture of the completed units, I've given them a coat of aluminium paint for now but may do as Frenchy suggested and cover the parts in some reflective foil once I have some.
anyway I'm happy with the finished result and it's certainly better than spending a few hundred pounds on new units when there was nothing wrong with the lenses and housings themselves just to replace the failed internal metal parts.
Now I wonder what horrors await me with the fog lights....???.. that's for another day..
Pete
