944 Electric Window weirdness
- Thread starter PaulHere
bmnelsc
While you are in there ... I had the drivers door switch act up on my last fall - could hardly press it down. Took the switch apart (simple with gentle prying between the switch back and sides) and I found the switch was dried out and the metal ball that "rocks" along the copper contact strip had fallen out of alignment. Again a thorough clean with electrical contact cleaner, a dab of switch grease (which helps hold the ball in place while you snap the switch back together) and it works great.
