944 door hinges
- Thread starter andyslade
Peter Empson
It might be worth double checking if it is actually the hinge, the reason i say that is I have the same fault and on mine its caused by a weld breaking inside the door. To check get someone to gently lift the door when its open and watch the hinge area. Apparently its quite common [
best regards,
Peter
Lemon
Like you Peter I believe it is not the hinge pins that are worn but as you say a weld inside the door (although I have not got round to taking the door panel off yet to check)
Has anyone remedied the weld and is it an easy body shop repair?
Lee
Peter Empson
Unfortunately our problem doesn't seem to have an easy fix, its not easy to get to the weld so the normal recommendation is to change the door, but it has been suggested to me that it should be possible to cut away enough of the metal inside the door to get to the weld. I've been living with mine for about a year and will attend to it when the car gets its paintwork done soon.
Best regards,
Peter.
On which subject, is it easy to remove the door. Obviously you undo the bolts, but what about the wiring and the restraining bit ?
