tinsoldier
Howdy,
I've a 1987 lux and the boot has never opened with the key. I checked it out and the cylinder itself was in bits (looks like something broke off)
I took the boot lock cylinder out and removed the barrel and put it in a replacement cylinder which is great, however the new boot lock cylinder has a 3 wire molex end on it and a switch that is activated when the key is turned (which i assume is the bit that broke off.
The problem is I can't find anywhere that this 3 pin connector connects in order to activate the boot motor,
has anyone got pictures of how theres is set up or any advice?
