Hi there,
I' m wondering if anyone out there has a wiring diagram for ' 86 930. The car was running fine when I reversed it into the garage but not the next morning! I found that the ignition cut off relay had failed and I' ve replaced it, but it still wouldn' t start. I think I have now traced the problem to the air meter/flow relay. I believe this should start the fuel pumps, but when it is switched the pumps don' t start. I think that the circuit that is switched should go to earth via some route, I can manually earth this connection to start the pumps and the car will run fine.
A wiring diagram or any useful advice will be much appreciated.
thanks
Stu
thanks
Stu
