Hi everyone,
New to the forum on here, I am looking to cut my teeth in the Porsche world and currently searching for a 930 turbo. Been into the VW scene for many years, quite handy with a spanner as a result.
I have a few questions, hopefully a suitably knowledgeable Guru on here can answer! Having driven a 930 and experienced the turbo lag, I would quite fancy converting to a more modern fuel injection setup with turbo control. Not doing this with the aim to increase power as such, just for driveability.
1) Does the 1984 930 use K-Jetronic or LE-Jetronic injection?
2) What intake manifold can I fit to a 3.3 engine to allow me to fit electronic injectors?
3) How much work is involved in converting 915 g/box to G50. I know G50 uses hydraulic clutch etc. Is it worth the hassle? Should I just get used to the 4-speed???
4) If I wanted to do something crazy like raise the CR on a 3.3 from 7.0:1 to 8.0:1 would I need to change the cylinder heads too? Has anyone tried this and kept the std heads? Which pistons are best to go for?
Ray
Ray
