928 style flat dish wheels
- Thread starter Guest
Paul Fraser
Paul Fraser
Aargh. Still p*ssing rain. OK, it says ET65 7x16 on two of them (they are all the same, I think).
http://www.1010tires.com/WheelOffsetCalculator.asp will let you work out the ramifications of changing to these from your (I assume) 23.3mm offset 7Jx15 cookie cutters on the pre 85.2 car you have. 40mm spacers I would have thought...
ORIGINAL: Paul Fraser
Mine is an early offset 944 but I haven't tried the wheels off the 928 on it. Hold on a minute...
Aargh. Still p*ssing rain. OK, it says ET65 7x16 on two of them (they are all the same, I think)....
The 87/88 Turbo had 928 style wheels as an option (they feature in the "...eats Ferraris" add). I have a set in the shed with my track tyres on. The fronts and rears are a different offset and a different rim width.
They also don't seem to provide much brake ventilation (which is very bad).
If anyone is desperate for a set I am more than happy to do a swap - my 928 dishes for pretty much any other set of 16" wheels which will fit my late hubs. They really are that good [&:]
pauljmcnulty
lali
Indeed.. I have got 16" tele's on my M030 calipered car and there is not a lot of space between the wheel and caliper. You also need to make sure that you get the right 16" tele's as the ones I got had funny lugs on the front wheels (pre ABS??) which meant that they wouldnt spin on the hub, they hit the calipers.[
So I ended up getting soem more rears and now run 8J16's all round. [
