Replacing the warm up regulator will greatly improve the cold-start performance of a car whose engine fires, then cuts out, and I am pleased to see that someone has provided some feedback for other members, as this now confirms some suggestions made in the 924 faq. about cold starting.
I am not discounting anh's suggestion, but here we are looking at an engine that wont even cough. I have in the past, stood in the drive with jump leads attached trying to start a dead engine, slowly richening (and leaning out) the mixture an eighth of a turn at a time, until the engine starts to struggle over tdc due to the volume of fuel in the cylinder. This would suggest that at some point I would have passed through the ideal stoichiometric ratio for perfect cold starting irrespective of the status of the w.u.r. but alas "de nada". The fact that a spark is present is decieving. Arthur Conan Doyle, as the creator of Sherlock Holmes, said whenever you have removed the impossible, what ever remains is the truth, no mater how improbable. So in the context of the non-starter, we need three thing to be present, just as in the triangle of fire; Fuel, air, source of ignition.
Let us examine what has changed.
Have we got fuel? Yes. Has the mixture been altered? No.
Air and fuel available.
Is the cam rotating? Yes.
Is the cam timing correct? Yes.
Air and fuel present.
We have elliminated two of the three things we need as being unchanged, therefore however unlikely, the source of ignition must be different somehow. The spark is controlled by the igniton module, and from bitter experience I know that they can fail but still produce a spark. What I cant say is whether the failure is due to the spark being too feeble
or occuring at the wrong time. I can say that on one occasion my engine did indeed run backwards with exhaust smoke coming from the air filter, which seems to suggest a spark occuring way too soon. The signal to the module is from an induction coil in the bottom of the distributor energised when the cruciform shape passes between two magnets. It could actually
be worth checking to see if the cruciform is in the right place on the distributor shaft, as I have seen that alter postion too, but only once.
