vitesse
Have posted here as the problems are (or could be engine wide)
Have a friend who has an early 924 which he has had resprayed over a couple of years-it hasn't run for 4/5 years so he's had it delivered to his home garage here in Formby & has asked me to get it going(he knows little about cars & engines & has also had a brain tumour a few years ago but is in remission ,but not able to crawl around cars too easily)
I went to look at it whilst it was in the sprayshop & the sprayer(allegedly a friend of my friend )said he had tried to start it but on each occasion petrol had flooded the engine causing a hydraulic lock in the cylinders-his conclusion was that the CIS was faulty & it needed a new fuel distributor.
The battery was low but I got 12 volts at the distributor & noted that it had points & capacitor,decided to leave it until at my friends house.
Have got the Haynes manual ,also my friend has the full Porsche w/shop manual & note that the very early 924's had points ignition with no ECU module,using ballast resistors with the coil.
At his house,I have found HT at the plugs,the fuel pump runs but haven't tried to start it as battery was low.
Suspicious about the hydraulic lock,I checked the oil level,was about 2 litres over level-smelt strongly of petrol so drained the oil which seemed to be 50/50 oil-petrol,removed the newly fitted filter again same contents-these actions 2 weeks apart to let any petrol remaining evaporate,refilled with flushing oil & fitted new filter.
Having removed all spark plugs(new) but heavily sooted,engine turned over several times with now charged battery but had removed king lead & fuel pump relay.
As I don't wish to risk repeating the flooding episode,my next job is to check over the electrics of the CIS-& this is where I need some advice or pointer to a better treatise of checking the fuel distributor/pressure regulator system/cold start system than the Haynes manual.
a)Can the fuel distributor be jammed internally such that it overfuels & floods the engine?
b)Is it more likely to be say electrical-like the thermotime switch/pressure control valve etc?
c)A combination of both?
Any pointers to a easier diagnosis without stripping the fuel unit would help-I haven't got a fuel pressure testing gauge-although most other things like multimeter,test lamp,strobe etc.
He also has a spare 924 donor car but electronic ignition with ECU module,so a spare CIS set could be stripped,reworked if necessary-I know the manual suggests using all new seals etc but as I am doing this in 1.5/2 hr visits I need a short cut approach.
Car refs:-1977 model chassis no 9247107220-engine-XJ000490
Spare car;-1983 VIN-WPOZZZ92ZDN402227-engine-XJ007592
Incidentally,the spare car remnants will be available to anyone interested.
