Following a clutch & release bearing replacement about 500 miles ago, I have noticed a transmission chatter on tickover which disappears when the clutch pedal is depressed. I use Millers 80W90 oil in box. Advice please from 3.2 owners on whether a change to another oil or using an additive like STP, or any other action or adjustment would help.
915 Gearbox
- Thread starter Clark
If the noise goes away when the clutch pedal is pushed down (disconnecting the engine from the gearbox) then the noise is coming from the transmission.
If the gears make any noise (grinding) when you change up or down then you better get it rebuilt as if left it will be more expensive to repair.
ORIGINAL: rob911
Sounds like the clutch release bearing - not the gearbox.
I agree. Unless it's LOUD don't worry about it, mine started making a noise probably 800/1000 miles after a new clutch kit and has never got any worse. If your box was on the way out you'd know about it; wouldn't be a small noise on tickover [
