911 Turbo
- Thread starter chriscoates81
It all depends..
It's a bit leggy so it's probably pitched about right. However, if it needs turbo actuators, rads, clutch, brakes, suspension... Any one of those will be a good reason for money off or free rectification. More than 2 & I'd walk away. Also, what dealer puts a car up with less than a month's MOT?
If it has a full OPC service history, you would expect them to have found any issues - they are good at that! Personally, I'm not a lover of the black wheels, but each to their own. The bum imprint in the driver's seat made me chuckle though.
I agree with Nick that it is pitched about right, but if you go for it get a decent inspection done.
chriscoates81
cheers for the fast response guys. I've entered a few details of my car on their website to see what they can do part ex wise. is there a list I should check off against or is it best to get a professional to do it?
Gordon Attar
That's priced to sell and is a reflection of the mileage, got to be worth a view and test drive. Don't forget to add on to check list a/c, rear tyre inside edges and for second gear jumping out
Gordon Attar
Also try here for 70k car for £2k more
http://www.pistonheads.com/classifieds/used-cars/porsche/911-turbo-996/porsche-911-turbo-cabriolet/1109702
DavidL
ORIGINAL: Gordon Attar
Gordon, its those wheels again isn't it. I'm sure you must have something to confess - too much gangsta rap I think!
Gordon Attar
Never bothered about wheels az they are easily changed(if you have the originals) or repainted for a couple of hundred pounds.
chriscoates81
ORIGINAL: NXI20
It all depends..
Is that the same thing as wastegate actuators?
Yes. The wastegates are in the turbo housing, and the get extremely hot, and can seize up, especially if not regularly used. The actuator is a vacuum operated device, which has a steel rod which connects to the arn which operates the wastegate. The rods also get hot, and because they are low down on the engine, are exposed to the elements. A good combination for corrosion. Having said that, my 996T had 86k on the clock when I sold it, and they were fine on mine. I did use it every day, and I think that helps.
chriscoates81
I think the one ive linked is a daily runner as its clocked up 10,000 miles a year.
chriscoates81
ORIGINAL: 75pno
It has no roof !
75pno
Does it knock much off the value if there is no hardtop? (obviously it does with a coupe[
