I have a 1987 3.2 carrera targa, which is fitted with an alarm and immobiliser. Can anyone advise if this is likely fitted as standard, or more likely to be aftermarket. The vehicle has been in storage for some time but now the alarm is being set off for no apparent reason. The alarm is switched on and off by use of a phono type jack plug inserted into a fitting in the centre consul, where there is also a red activation light. I do not have any further details or paperwork on the alarm system. Thanks
			You are using an out of date browser. It  may not display this or other websites correctly.
911 alarm and immobiliser
- Thread starter Colin mccashey
Not likely standard.  I had a Cobra system on mine that had probably been installed in the 90's, didn't prove too much hassle provided you remembered to put the car on a charger when not in use.
As others have said, if you want an alarm there is likely far better on the market these days.
Ben
Ben
Thanks for replies regarding the alarm system. I agree with the sentiments, rip it out. Not so easy though, as I tried this a few years ago and local auto electrician wasn’t keen. Turns out the alarm is an AA approved Foxguard system installed in 1996. Spoke to a very helpful man at Bridgewater Electronics, Somerset, as recommended on a Pistonheads Forum, who advised on potential faults and removal. Thanks again for all the advice, and the alarm will likely be removed.
			Car52
Yes I think you‘re right ... it may not be quite as simple as just ripping it out ... in my 911 3.2 "previous invoices file” there’s an invoice somewhere for "removal of alarm and immobiliser” by a specialist indie ... ??Colin mccashey said:Thanks for replies regarding the alarm system. I agree with the sentiments, rip it out. Not so easy though, as I tried this a few years ago and local auto electrician wasn’t keen. Turns out the alarm is an AA approved Foxguard system installed in 1996. Spoke to a very helpful man at Bridgewater Electronics, Somerset, as recommended on a Pistonheads Forum, who advised on potential faults and removal. Thanks again for all the advice, and the alarm will likely be removed.
