I am very pleased with main-beam performance on these LED headlights but less so with dipped beam.
The driver's side dipped beam appears to be aimed very low, compared with the passenger side, even allowing for the cut-off pattern.
I assume that any aiming adjustment has to be done via software, rather than a screw-driver fix?
If so - is this a dealer-only job, or can it be addressed via something like Carly (or other similar dongle/app combos)?
Maybe I also need to check whether the switch-on self-check beam down/up movement is happening properly (just in case)?
