4 speed transmission parts HELP
Timspu
I have my 1988 4 speed transmission being repaired and am in need of a guide sleeve part number 930.302.402.00 . Porsche will not have stock till February and the one i received from the USA made by Hoer of Germany is too small to fit the shaft by 1mm, most probably a 915 part which had been marked as a 930 part. If any one has a good used one or know of where a new one can be purchased it would be of great help.
TIM
TIM,
Rose Passion seem to have it in stock under part number P31063, I used them for engine and transmission bits a couple of years ago and found them very reliable and cost effective.
Good luck,
Peter
Its a Porsche only part Im afraid so you wont get it OEM. Rose Passion wont have it in stock Im sure.
Had a huge problem, it appears Hoer do make them but have been identified incorrectly, i received two and both were 915 parts even though they were in 930 packaging. So i have had to put the original back in. Porsche still had no forecast for availability of this part. Quite dissappointing.
Thanks for the responses
TIM
