Markethouse356
I've recently bought a beautiful old car but unfortunately the rear bearing O ring has leaked onto the brake shoes. It was restored 10 years ago and on inspection the rear axle bearing flange has been damaged so that the O ring between the flange and shim will not seat and hence leak. I would be very grateful if someone could advise how to remove the axle bearing flange together with the half shaft tube that is shrunk onto it. Many thanks
