Hi All,
I want to put a 3.0 16v engine into an 8v car. To do this I will need to use the crank trigger arrangement from the 8v engine. Am I right in thinking I can use the flywheel, bellhousing and crank sensors from the 8v engine on the 3.0 block? Does the 3.0 16V have a different clutch to the 2.5 8v models and if so would it fit on the flywheel from the 8v? The flywheel teeth are also important for the 8v triggering arrangment so would this be in the same place?
Tom
Tom
