265 rears fit on a C2 ???
- Thread starter Guest
Dave Wilkinson
As long as the offset on the wheels is around 47mm I believe the 265 tyres will be OK - just. It doesn't leave a great deal of room on a narrow body and it does, I believe, depend on the make of tyre - some are better than others. You should check clearance for the oil pipe in the right rear wing and, more obviously, the wing itself.
Dave
tim_haskins
tim_haskins
Dave Wilkinson
8.5J is too small for the rear. The sets which are produced by Mille Miglia are 8.5J/ET52 for the front and 10J/ET47 for the rear. As long as the rear wheels are 47mm offset (which I'm sure the supplier can confirm) you will be OK. It would be a shame to spend a load of money on wheels which are just the wrong size.
Any web links to the wheels you are ordering??? Maybe we can check them out for you.
Dave
