2018 Macan ABS/PSM/Suspension/4 wheel drive fault plus occasional brake distribution fault
911dbx
Having been faultless for the the 8 years and 86000miles i've had the car from new, it threw up these faults on a trip to Cornwall last week.
Other than disabling some functionality the car seemed fine so I carried on to my destination. Took the car to a local garage to have it plugged in and check the issue and seemed to be an ABS sensor fault. Cleared them and drove it around for 30mins and they didn't reappear.
As suspected though, they returned in earnest on the return trip quite early on. I stopped quite a few times and switched the engine off and on and they cleared often and also cleared when driving (apart from the 4 wheel drive fault) and then stayed on for the last 100miles or so.
Booked into Porsche this week so hoping it's just the ABS sensors and nothing more involved.
I had exactly the same issue in June last year with my Macan, it was the nsf wheel sensor. It went on the M1 coming home one day and once home I didn’t fancy driving it so had the RAC come and replace it at home. It had done about 80,000 miles at the time!
Unfortunately the problem reoccurred just two days ago so another one to be replaced now.
This is a common fault with the Macan and it's wise to change all four
I had two on the same axle changed but prob should have asked for all 4 as you say. Do they need recoding after fitting a it does look like a job i could do at home?
That's great and should now give you peace of mind. You should be ok as I believe there is no requirement for coding via Porsche.
