Hi, looking for a little technical help . I have a 2007 Porsche Boxter which was started and idling when it simply cut out. The car starter operates but will not start. I have plugged in a code reader (TOPDON ArtiDiag500 S - I know, its a cheap code reader, however it has come up with the following codes:
P1610 (No Communication with A/C),
P0503 ( Vehicle speed signal PSM/ASR),
U0155 (lost communication with Instrument cluster control module),
P1640 ( Ambient Temperature from instrument cluster),
P1603 check POSIP control fault memory content),
P1614 (no communication with steering wheel ECU CAN drive)
U0129 communication ride height control unit),
U0167 (communication PAS control module drive)
U0146 (communication gateway CAN drive),
80C5, 80C6, 80C7 (all say Triggering unit faulty),
C152 (Communication PSM control unit),
C158 (communication gateway control unit CAN drive)
4444 (steering angle sensor not initialised),
4223 (fault in DME read out fault memory).
I appreciate all of these are communication errors (CAN bus).
Reading some info on line suggests that the instrument cluster is a likely cause.
Has anyone experienced similar and can shed some light on the most likely solution.
Kind rergards
Kind rergards
