Hi,
One headlamp washer ( LH ) continues to leak following use, quite quickly draining the washer fluid tank and causing the warning message to appear on dash.
Is the solution possibly simply the one- way valve at the washer head that needs replacing, or something more complicated?
Will the front bumper need to be removed to access the washer system , even if only the one- way valve is the issue?
The headlamp washers seem to be working well apart from the leaking issue.
Any advice would be appreciated.
Thanks,
Chris
Thanks,
Chris
