Rear Spoiler problem. Firstly failed to retract and I traced problem to faulty relay. Replaced relay and all ok. Spoiler operates fine when going. Yesterday checked it went up and down many times so put it in garage thinking I had solved problem. Today problem back again - went up and stayed up so I swopped the relays over again and it goes down but will not go up again unless I swop relays over again. Both relays are operational so there is obviously something loose somewhere - checked wiring but nothing obvious. Disconnected battery whilst I looked at manual switch - reconnected and spoiler operated normally twice then back to sticking up again!! Got me foxed and wondering if micro switches are plying up although it worked perfectly well yesterday!! Any suggestions would be greatly appreciated!
Thanks, Neil.
Thanks, Neil.
